power steering for an M
DJL
06-03-2006 23:05:02
I've got an M with a narrow front and two hydralic remotes. Can an after factory power steering unit be added to this tractor? If so, what do I need....a charlyn motor? How much money would I be looking at for this? Thanks
IA Roy
06-04-2006 22:25:32
 Re: power steering for an M in reply to DJL, 06-03-2006 23:05:02
Our M had a distributor drive pump for the hydraulics, and a belt drive auto style pump for the power steering. They both worked fine, but I think if you used a priority valve and just the distributor drive pump it would work the same.
Allan In NE
06-04-2006 05:00:44
DJ,
A new motor and priority valve will set you back $685 plus you'll have to find a bracket somewhere to mount the thing. Add the hoses and fittings and you're easily over $700 if you use new stuff.
I used all used pieces on my H including the pump and after the dust settled, it crowded $1100. :>(
Allan
Steven@AZ
06-04-2006 06:57:56
 Re: power steering for an M in reply to Allan In NE, 06-04-2006 05:00:44
I got my live hydraulic and power steering done up for around $650 with all new parts. Took about a year and a half of shopping around to do it, but I wasn't in a hurry.
Watch eBay, watch the ads on this site, etc. and you can get by cheaper.
Northern Tool has the priority valve for around $75, my pump cost around $375, and I scored a complete power steering set up for an M for $300 and sold the extra pieces for $200 so I got the torque motor for $100. Just takes time to find the deals...
