Farmall 240 weight
Warrenag
06-04-2006 08:36:43
I will be traveling to pick up a Farmall 240 tractor next week. Any idea of the weight of the tractor????? Don't know if my trailer will be able to handle it...trailer is rated at 2700 lbs
Thanks for any and all help
sammy the RED
06-04-2006 20:39:04
 Re: Farmall 240 weight in reply to Warrenag, 06-04-2006 08:36:43
3360 lbs.
CNKS
06-04-2006 13:30:01
Hugh is correct, no less than 3000 lbs, depends on rear wheel weights, and fluid in tires. Could push 4000. You need a tandem axle trailer with brakes.
Hugh MacKay
06-04-2006 09:37:51
Warren: A Farmall 240 will be at least 3,000. I can remember Super C and 200 weighing in at tractor pulls, never saw one under 3,000 lbs and it is the same basic chassis as the 240.
BillWv
06-04-2006 09:21:38
I think that a 240 weighs more than that. But are you sure it will physically fit on your trailer? I would have to think a trailer rated at only 2700 pounds must be single axle.
My Super C barely fits on my tandem-axle trailer.
Good luck,
Bill
Darin in Nebraska
06-04-2006 09:15:44
I have a International 240 Utility gas and when I weighted it, I beleive it weighted right around 3,400 lbs. I do not have any fluid in the tired. So that should be just the bare tractor. Hope this helps. Darin
doodelbug
06-04-2006 09:08:23
try tractordata dot com , all kinds of good info.
