H won't start!!!!
1951farmallh
06-04-2006 10:35:11
I just used my "51 H 3 days ago. Nothing seemed wrong. Today, i went to start it and it turned over fine, but wouldn"t start!! Gas was dripping from the carb after awhile of trying. This tractor usually starts very easily. I tried every hour and nothing. What could be the problem? I need this tractor for raking hay and the hay is getting taller. Thanks for any help!
Grag
06-04-2006 16:24:34
 Re: H won't start!!!! in reply to 1951farmallh, 06-04-2006 10:35:11
Try pulling it with another rig.
Nat 2
06-04-2006 18:01:10
 Re: H won't start!!!! in reply to Grag, 06-04-2006 16:24:34
Don't bother. If it'll turn over decent on the starter, then pulling it is just as much of a waste of time as trying it every hour without so much as a half-hearted effort at troubleshooting...
Sir, original poster, you've got to try SOMETHING to fix the tractor... They don't heal like people and animals; time isn't going to make the problem mysteriously go away like a paper cut.
Air, fuel, and fire, all at the right time. That's what makes an engine run. If you're lacking one of those, then the engine will not run.
Nebraska Cowman
06-04-2006 12:11:55
yup. if there is gas dripping that would be normal on a no-start. Could be something as simple as forgetting to turn on the switch but I'd suspect poor spark. The sparkplugs could be wet from trying too. I'd pull the plugs and see what they are doing. third party image
old
06-04-2006 11:41:55
Check and see if it has a good blue spark. I'd guess you may need a new set of points. Doesn't take much dirt etc to stop the points from working
arod
06-04-2006 11:55:11
 Re: H won't start!!!! in reply to old, 06-04-2006 11:41:55
6 volt generator or 12 volt alternator?
distributor or magneto ignition?
1951farmallh
06-04-2006 12:16:57
 Re: H won't start!!!! in reply to arod, 06-04-2006 11:55:11
the tractor has a 6 volt system with distributor. I will pull the plugs and see what's happening.
arod
06-04-2006 12:19:40
 Re: H won't start!!!! in reply to 1951farmallh, 06-04-2006 12:16:57
ok,
perhaps the points and cap got moisture in there somehow. pull the cap and make sure is dry. Then pull a plug wire and check for spark.
