H, taking top gear assembly out of tranny?
arod
06-04-2006 11:44:40
have top cover off. now what? have a failed roller bearing on the front of the top shaft, need to replace, just intuitively take apart?
I must split the rear end off?
Nebraska Cowman
06-04-2006 12:14:55
 Re: H, taking top gear assembly out of tranny? in reply to arod, 06-04-2006 11:44:40
just pull the imput shaft out the front. It should be all out in the open then.
third party image
arod
06-04-2006 12:35:52
 remove the belly pump? in reply to Nebraska Cowman, 06-04-2006 12:14:55
so remove the belly pump?
Nebraska Cowman
06-04-2006 14:15:33
 Re: remove the belly pump? in reply to arod, 06-04-2006 12:35:52
yes
