Air cleaner problems on Farmall C
Jack82
06-05-2006 08:00:27
My C was choking to death after running at high rpms for 10 minutes or so. I disconnected the air cleaner from the carb and it runs fine. After cleaning all of the crud stuck to the roof of the air cleaner intake, I thought I had solved the problem. But I am still having the same trouble. There has to be more crud built up inside the air cleaner body. Any ideas on how to clean that out? Also, what weight of oil should I be using in the bottom cup on the air cleaner? Could too heavy an oil be causing this problem?
Thanks!
Dan Bear Kelley
06-07-2006 11:20:00
 Re: Air cleaner problems on Farmall C in reply to Jack82, 06-05-2006 08:00:27
I agree with Red Dave. Kerosene soak it. Another thing you could try is going to the car wash and using a high pressure soapy spray.
Shaggy
06-05-2006 12:03:30
I pulled the mesh out of 1 of mine and replaced it with the foam for a snowmobile air filter. I cut 2 disk's out and put some K&N air filter oil on them to help catch the dust and dirt. But you will need to do some work on the carb because the extra air will lean it out some.
Red Dave
06-05-2006 08:17:28
Put about 3 or 4 gallons of kerosene in a 5 gallon bucket. Then take the oil cup off of the air cleaner and remove it from the tractor. Soak the whole thing in the kerosene overnight, longer if possible. If it's really bad it might need a second round.
Use 30 wt oil in the oil cup.
