IH 1066 Reverse and Parking Brake Problem
Mitchell Dabbs
06-05-2006 08:44:13
Hello. I have a 1972 IH 1066 Tractor, non T/A, and recently I have been having problems with the tractor when I put the shifter in reverse. The tractor SOMETIMES jumps out of gear as I am backing up and makes a horrible grinding sound. If I back up slow or fast it doesn't matter. If I keep my hand on the shifter it seems to help it to not jump out of gear but SOMETIMES it will anyhow. Also, the parking brake used to hold but lately it seems that it is failing so much that I never park the tractor on a hill. I would appreciate any ideas about what is wrong with the tractor and how to fix it. Thanks again. Mitch.
the tractor vet
06-05-2006 09:03:56
 Re: IH 1066 Reverse and Parking Brake Problem in reply to Mitchell Dabbs, 06-05-2006 08:44:13
Well to start with i would say that ya need to work on the shift linkage from the shifter all the way down to the range transmission cover and repair replace any woren parts . If this does not fix the problem then one must go deeper in . The rev. shifter and gear can be checked by removing the side cover on the rearend behind the left steep , if the trans mission oil level is where it should be and not over full then when you remove the cliped coner cover you will only lose about a gallon and a half of Hyd oil . Sometimes on of the ends on the shifter fork breaks off and this will allow it not to stay in gear. Also if ya have to remove the range transmission cove this cover must come off also . As for the park lock if it is the old style of over center NOW is the time to upgrade to a spring loaded park lock , kits can bought from Case I H .
