super c questions
ironfloats
06-05-2006 12:42:04
I have a few questions concerning a super c.Did 2pt hitches come standard.Is that the biggest difference between a super c and a c?I want to convert to a 3 pt does any one have plans on how to do this?Last question,I picked up a set of cultivators that bolt to the rear axle but they won't fit because the hydraulic clclinder is in the way.Does this mean they're for a c?Thanks for the help I'm still learning.
CNKS
06-05-2006 17:17:27
 Re: super c questions in reply to ironfloats, 06-05-2006 12:42:04
C's and early Super C's did not have fast hitch. It was available (standard, I don't know) on the later Super C's. You cannot use equipment that bolts to the axle unless you remove the fast hitch. There were fast hitch cultivators manufactured. You best bet is to get a 3 point adapter and a three point cultivator, unless you are lucky enough to find a fast hitch one.
BillWv
06-05-2006 16:26:05
The 2pt Fast Hitch was not standard on Super C's. The biggest difference between the C and SC is probably the engine in the SC has 10 more cubic inches (113 vs. 123). There are a few small changes, some visible, some not.
I don't have plans for a 3ph adapter but my SC has one installed; I can provide pictures if you want. The prongs are pretty easy to figure out; on mine, the top link mounting bracket replaces the belt drive pulley unit. The adapter works fine overall; the geometry can be a little strange with some implements, but I've used it with everything from finish mower and bush hog to carry all to turn plow. Right now my box blade is on it, and it's so handy I just leave it on.
I posted a picture from some old advertising of the factory 3ph adapter. Link below.
Bill
MikeinKy
06-06-2006 07:09:19
 Re: super c questions in reply to BillWv, 06-05-2006 16:26:05
Super C had curved pedals, water pump,disc brakes,10 more cubic inches. 53 & 54 models usually had fast hitch.
