International 300 distributor drive
Jared Chaddock
06-05-2006 14:22:06
What kind of lube should be used in the distributor drive on an IH 300? (The casting between the distributor and hyd. pump) Also, should there be some sort of seal in the tach drive? I originally tried motor oil in the drive and it leaked out thru the tach drive. I took it apart and it doesnt have any type of seal in it now. Thanks in advance.
PAULIH300
06-05-2006 15:28:10
 Re: International 300 distributor drive in reply to Jared Chaddock, 06-05-2006 14:22:06
It gets greased with regular chassis lube thru the grease fitting,but you dont pack it solid.Just enough to lubricate.
