I 184 tractor need info
heavyduty
06-05-2006 19:33:03
what oil weight to use, tranny hydraulic fluid or what?
Fred Mills
06-07-2006 05:35:37
 Re: I 184 tractor need info in reply to heavyduty, 06-05-2006 19:33:03
Be sure to check the gear boxes on each wheel. There is a level check plug on the rear side of gear box. This is the rear axle housing. use hy-tran.
It is critical to grease the clutch release bearing carrier once per year or more. You will have to remove the frame cover to get to the zert.
heavyduty
06-07-2006 11:33:50
 Re: I 184 tractor need info in reply to Fred Mills, 06-07-2006 05:35:37
Thanks Fred, good info to know.
Nat 2
06-06-2006 06:21:19
It would help if your question made sense. All I can tell is that you're trying to change the oil somewhere on your tractor, but where?
Here are answers to some common questions:
30 weight in the engine
Hy-Tran in the hydraulic reservoir and/or transmission.
I don't know if the 184 has a separate hydraulic reservoir or if it uses the transmission as a reservoir. You should get yourself a reproduction owner's manual that tells you all this stuff.
heavyduty
06-06-2006 12:31:12
 Re: I 184 tractor need info in reply to Nat 2, 06-06-2006 06:21:19
Just bought it, wanting to chg engine oil,thanks for the weight on that. I only see one port rear and tranny. So hydraulic fluid is what I should use? I will purchase an owners booklet, but I wanted to check now so we could use it to mow now.
