Need PTO bearing part number
biggerred
06-06-2006 09:00:45
Last week I posted about the pto on my 300 that would not stop. I took the unit apart, and off the tractor. When I removed the cover(on the end that sticks into the rear end of the tractor) ball bearings went all over the place. I guess one of them, or the fact that everything was out of line, was causing the problem. I can't read the part number on the race. It's the first bearing you come to from the short shaft on the inside of the rearend (small bearing.) I might need a bearing for the sun gear also. These should be an adventure to find!! thanks
PAULIH300
06-06-2006 09:08:39
 Re: Need PTO bearing part number in reply to biggerred, 06-06-2006 09:00:45
If it has Independent PTO,
the IH #s should be ST564 rear
ST559 front.
These use snap rings.
I believe these are the ones you are looking for (??)
biggerred
06-06-2006 12:02:40
 Re: Need PTO bearing part number in reply to PAULIH300, 06-06-2006 09:08:39
the larger of the 2, (being the bearing for the sun gear) has the snap ring in the outer race, but the small one is only held by a snap ring, and has no ring grove for the snap ring in the outer race.
PAULIH300
06-06-2006 12:07:05
 Re: Need PTO bearing part number in reply to biggerred, 06-06-2006 12:02:40
Please unhide your e-mail.....I'll forward you some info.
biggerred
06-06-2006 11:58:50
Yes it is the independant PTO, thanks!!
biggerred
06-06-2006 11:58:41
PAULIH300
06-06-2006 12:02:48
 Re: Need PTO bearing part number in reply to biggerred, 06-06-2006 11:58:41
Should be the ones,but if you can get someone to cross over the IH#s,have them check the dimensions against what you have.
