560 frame width
Geoff NY
06-06-2006 15:30:58
Have a chance to get a D 282 from a TD 6. Want to put it in a SWD 6. The frame rails are 4 inches wider on the dozer, can someone tell me if the F560 was wider also? (same motor) I know the rails would have to be extended that"s ok, but I wouldn"t want to make it wider.
CNKS
06-06-2006 17:47:34
 Re: 560 frame width in reply to Geoff NY, 06-06-2006 15:30:58
I'm not at all familiar with crawlers, but the original engine in a TD6 was a start on gas 4 cylinder D248; the D282 in a 560 was a 6 cylinder, the engines are in no way related. The SWD 6 had a D264, I do not know if the D248 in the TD6 was upgraded to a D264 or not, as I have never heard of a Super TD6. That is not to say you can't put the D282 in your 6 series tractor, but it is not a direct bolt in.
Geoff NY
06-07-2006 02:56:25
 Re: 560 frame width in reply to CNKS, 06-06-2006 17:47:34
The TD 6 went to the 282 (6 cyl) in the late sixties. It was not labeled a super, simply called a late series. I know that the motor is not a simple drop in as the frame rails would need to be extended 4 inches. I am mainly trying to find out if the motor is physically an acceptable width to fit between the frame rails. As always thanks for the input. Geoff
K.B.-826
06-06-2006 16:09:41
560 is right about 19 3/4" wide across the frame rails. Don"t know about a Super W-6. I was thinking a 560 was the same width as an M, so by rights your W-6 engine should be the same width. Remember, the TD-6 may not have the same front cover and rear plate as a 560.
