Major problem
old
06-06-2006 17:34:01
Well I now have 3 Hs but the problem is I only have 1 starter for the 3 of them. Will a starter from a B work?? I know I could just give it a try but would prefer to know if it will or will not, please help.
Thanks
Nat 2
06-07-2006 05:18:07
 Re: Major problem in reply to old, 06-06-2006 17:34:01
Translation of the responses below:
The B starter isn't as strong as the H starter because it's designed to turn over a smaller engine. It will probably bolt up, and may work, but probably won't last long due to the motor being overloaded.
Chuck's Repair
06-06-2006 19:42:23
An H has four field windings,I believe a B has only two.
PAULIH300
06-06-2006 18:28:28
I show that they have different IH part #s.
RustyFarmall
06-06-2006 17:44:27
If you have a parts manual for both tractors you could look up the part numbers and see if they are the same, or place both starters side by side and compare. That's how I would do it.
Bruce Wa.
06-06-2006 17:42:58
yes
