A134 CULTIVATOR
MJ in the UK
06-07-2006 09:39:08
Hi folks. Nearly finised restoring my Farmall B. When I got the tractor it had a hand lift unit on it just like the one in my A-134 cultivator book. My question is about the lifting rockshaft part number 28872BA. My rockshaft as the R.H. arm turned out and the L.H. arm turned in. On the B tractor should the L.H. arm be turned out to match the R.H. arm. Regards Michael.
MJ in the UK
06-08-2006 09:17:41
 Re: A134 CULTIVATOR in reply to MJ in the UK, 06-07-2006 09:39:08
Thanks for the info Gene. I now know what i have to make for thi little tractor. Michael
gene bender
06-08-2006 03:26:14
Yes the left side should be turned out just like right side. Question on the A-134 does the lift lever mount by the gearshift with one end bolting to the boss rear ot the shift lever and other end mounting to the steering post? This being the case then both sides are lifted with one lever. I also have the two lever set-up on a A-437 and also an A-138.
