Farmall H 1st gear
Jfarmall
06-07-2006 16:24:43
Hey everyone,
I know that the Super H has a faster 1st gear than a regular H, so my question is can you change the gear in a regular H to make it the same speed as a super H?
Thanks
RustyFarmall
06-08-2006 04:44:24
 Re: Farmall H 1st gear in reply to Jfarmall, 06-07-2006 16:24:43
There was a special "low speed" 1st gear available as an option on the H, If yours has this option, then the super H 1st gear would be faster, but otherwise the gears are the same speed. Quite a few tractor pullers are looking for that low speed 1st gear.
Andrew Z
06-07-2006 18:07:56
First gears are the same in regular and a Super, all the other gears in a Super are faster. 2 5/8 mph.
Andrew
Dr.EVIL
06-08-2006 09:40:08
 Re: Farmall H 1st gear in reply to Andrew Z , 06-07-2006 18:07:56
Just 2nd, 3rd, & 4th were different..... 1st, 5th & reverse are the same. That's assuming same tire size & engine RPM.
