Farmall M, checking oil
Timmer81
06-07-2006 20:51:20
I just bought a 1944 farmall M, Runs great need a little paint. How do i check the engine oil, and hydraulic oil in this tractor, and also is there a site out there to buy rear tires too??
Hfarmall
06-08-2006 19:09:07
 Re: Farmall M, checking oil in reply to Timmer81, 06-07-2006 20:51:20
Hi, I would buy a operators manual they will tell you all the specs you need to know. That way you know your tractor better.
Nat 2
06-08-2006 04:54:40
Shipping tractor rear tires is prohibitively expensive. They're HUGE and HEAVY. They're certainly not going to arrive in the brown truck. You're best off finding a tire shop that deals in ag tires in your area (check the yellow pages) and dealing locally.
Will Sick
06-07-2006 21:16:39
There are two petcocks on the side of the oil pan. Oil level should be between the two. Capacity is 8 quarts. The hydraulic fill cap is beneath the gas tank. Remove te cap and if your lucky there is a dipstick. If not you can stick a clean wire down to make sure it at least has oil in the pump. It's not good to run the pump without oil. My M does not have a dipstick in the hydraulic filler so I just make sure it has a couple of inches of oil . Then if I'm using the pump I add enough oil to lift what ever. If you overfill the hydraulics oil will come out the filler when you drop an implement.
Timmer81
06-07-2006 21:27:34
 Re: Farmall M, checking oil in reply to Will Sick, 06-07-2006 21:16:39
Thanks Will, im going back 40 years to remember this, My grandpa showed me but i cant remember
