Need a puller
RNicholas
06-08-2006 18:58:40
Okay, I give up. I don't have time to go to a shop and have one made and I don't have time to take the engine to the shop to have it done, so anyone out there that has a pulley puller to get the crankshaft pulley off a 100 please email me and tell what you have (or can make) and how much it'll cost me. And please be a friend and don't charge me three prices because I'm so busy I can't see straight!
rlnassociates@aol.com
Haas
06-09-2006 18:15:34
 Re: Need a puller in reply to RNicholas, 06-08-2006 18:58:40
There was a lot of discussion about pullers for the Super A/100 crank pulley a couple months back. Search the archives and you can probably find it. There was even a picture of a home made puller. These crank pulleys are really on there tight, so it takes a heavy duty set up to get them off. And a bearing separator type set up is required that fits behind the hub of the pulley. Don't try to use a jaw type puller on the flanges of the pulley, or you will just break it and then you will be using your time to hunt a new pulley. Best to not rush it and do it right.
doodelbug
06-08-2006 21:45:00
dont know where your at but around here you can get one at the auto parts store. think you can rent them at autozone. just a common crank pully puller. most are adjustable as to size. hope this helps.also you can look on ebay and learn about them, then they think you know a little about it when you go to buy it. LOL.
