worn upper bolster/400
SDE
06-08-2006 19:38:49
Pulled the upper bolster out tonight. The thrust bearing was packed tight with mud. Hasn't moved in years. The shaft ,below the splines, should be 1.499 in diameter. At the worn spot it is 1.483. How or what is the repair for this? Turn it undersize and install a undersize bushing?
JonT
06-08-2006 19:59:18
 Re: worn upper bolster/400 in reply to SDE, 06-08-2006 19:38:49
You can replace the bushing that is pressed into top of the pedestal assembly directly below the gears. I"ve done it before on an M and it worked well. I"ll try to find the bushing number tomorrow.
