superc engine torque specs
DAVISFARMS
06-09-2006 19:28:24
can someone tell me the specs on rods,head,valve gap
El Toro
06-10-2006 04:39:05
 Re: superc engine torque specs in reply to DAVISFARMS, 06-09-2006 19:28:24
The valve setting is .014"H, I would set them at .017"C until you get the engine running. The cylinder head torque is 80 ft-lbs. My manual doesn't list the rod torque for the Super C, but does list it for the A, B & C which is rod nuts
locked with cotter pins is 40-45 ft-lbs or if selflocking nuts are used then the torque is 43-49 ft-lbs. Hal
