6-volt lights
twine
06-10-2006 06:28:29
Hi just wondering how would be a good ideas on putting that rubber boot on farmall h light set.Its the ones with that short peice of flat steel on the ground screws,and the other screw is for power.Does the bulb go so you can read it.and that ground steel strap is on the side .Can you still buy a 6-volt bulb any more ,GE 4510 is the number on it.Just wondering if you wouldsoap it up really good will help?
Janicholson
06-10-2006 06:52:38
 Re: 6-volt lights in reply to twine, 06-10-2006 06:28:29
Bulbs have been available at NAPA, reading the words correctly works fine, The best I've used is silicone spray, or silicone grease. Watery stuff in the housing rusts parts, silicone keeps it out. A small hooked wire tool can save much grief. Polish the wire to limit snagging. JimN
