Farmall B drive shaft
Jeff Peterson
06-10-2006 06:47:38
My drive shaft has been worn by the throwout bearing so I need a replacement. Will one from an "A" fit a "B"
Thanks Jeff
Mark in WA
06-10-2006 13:29:28
 Re: Farmall B drive shaft in reply to Jeff Peterson, 06-10-2006 06:47:38
The drive shaft should be the same on both tractors. The main difference is the narrow front end and the extra wide rear end. The engine, clutch housing and transmission are all the same.
Jeff Peterson
06-11-2006 05:38:17
 Re: Farmall B drive shaft in reply to Mark in WA, 06-10-2006 13:29:28
Thanks
Jeff
