Dang Flat! OT
Peabody
06-10-2006 19:18:22
Well, got the front tire remounted on the Cub today after having pulled it off THREE times to fix a hole in the tube. Had it done professionally this time, guy rubbed the burrs off the rim and put a piece of rubber "gasket" around the stem where the rim was kinda rotten. Put a boot in it. FYI, neither Bubble Gum, Slime nor Fix-A-Flat works to seal a pinhole leak on the inside of the tube (the part that contacts the rim). That stuff only works for a puncture on the WEAR SURFACE of the tire, where the centrifugal force of driving the tractor can place the goop over the leak to seal it. That tire better be up tomorrow morning!
Turbos10
06-10-2006 20:58:47
 Re: Dang Flat! OT in reply to Peabody, 06-10-2006 19:18:22
Glad I am not the only one having trouble today. I am working like mad trying to get my puller ready for next weekend's local pull. After taking the rear tires to the local shop and getting a couple boots to fix my tire cutting learning curve....One of the damned things had a patch come off the tube today or somthing. I was getting the tires seated, cause the tire shop did a poor job, and when I started letting air out it started hissing around the stem. Hopefully they can fix the tube and will not try to charge me again.
