H brake problem
rhud
06-11-2006 08:10:51
Trying to get a "new" H ready for a tractor tour my daughter is in.. the right brake pivot is rusted in the transmission houseing. i've been spraying it with pb blaster and the like and tapping the pivot from the top, bottom, front, back for about three days now....I know this is a common problem and others have freed the pivot, but none of the post explain just how it was freed. Any ideas fellows...Thank You
kfox
06-11-2006 10:26:43
 Re: H brake problem in reply to rhud, 06-11-2006 08:10:51
I used the same system your using. Just had to "worrie" it out. One took most of a day. It should have a thin brass bushing in the hole. If worse comes to worse, you can still get new bushings. Put some grease in the hole when you put it back togather. ken
sammy the RED
06-11-2006 08:41:56
Gas Wrench ?
rhud
06-11-2006 20:01:45
 Re: H brake problem in reply to sammy the RED, 06-11-2006 08:41:56
yeah, but i'm saving that for a last resort....
