Where to get cheap SW6 wiring harness.
JaredM
06-11-2006 10:57:25
I'm fed up with tracing and replacing wires and I was wondering if anyone knew of a place to get a wiring harness cheap for a Super W6. It has been converted to 12 volt but I can deal with that or maybe you know somewhere that makes them 12 volt. My boss said OEM Tractor Parts had them but they are $190 with the fancy cloth braiding etc. Its a work tractor so I don't want a show quality piece on it. I also would rather not do it myself. Thanks to anyone with ideas or suggestions. JaredM
R.J.
06-11-2006 19:01:57
 Re: Where to get cheap SW6 wiring harness. in reply to JaredM, 06-11-2006 10:57:25
Here you go Agri-Services at 1-716-937-6618
or www.wiringharnesses,com they can fix you up.
R.J.
06-11-2006 18:59:22
Marty Johns
06-11-2006 18:05:37
Do it yourself!!!!! I just redid and A and it was'nt that tough and a whole lot cheaper! $30.00 vs $120.00 for a factory replacement! I had to post here a couple of times to make sure all was right as I had a couple of broken wires, but it worked out!!!!! !!!
El Toro
06-11-2006 15:24:44
Try the Brillman company at 1-888-274-5562. Hal
