M carburetor high speed adjust
Chris B.
06-11-2006 14:14:31
Was out fiddling with the M carb this afternoon. Noticed that closing the high speed screw would stall the engine (as expected) but backing it out and even removing it had no effect. Tractor seems to make good power and starts well by hand. (Though, my only reference is a Cub and anything makes good power compared to a Cub.)
High speed adjust is set to about 4 1/4 turns out.
I'm not too sure about this one.
Thanks, Chris B.
RustyFarmall
06-11-2006 15:04:44
 Re: M carburetor high speed adjust in reply to Chris B., 06-11-2006 14:14:31
If you took the high speed screw clear out you should have had gasoline running out the hole. How thorough were you when you cleaned the carb?
Chris B.
06-11-2006 15:07:33
 Re: M carburetor high speed adjust in reply to RustyFarmall, 06-11-2006 15:04:44
Rusty, I thought about that and gasoline didn't run out when the engine was running, but I only kept it out for a second or 2. Anyway, I went back outside and pulled the adjust screw and fuel came pouring out of the bowl. Nice and clean.
Chris B.
MagMan
06-11-2006 14:41:36
I would say something is pluged in the carb. Needs a good soaking and cleaning and blow out ever orfice. The standard setting is 3 turns I believe. Now the SM carb I have on my H the main jet it about 1/2 turn out and thats all she will take before burning black. How about the air mixture does that make a difference in idle . With running or black smoke when you turn it in? JON
Chris B.
06-11-2006 14:58:21
 Re: M carburetor high speed adjust in reply to MagMan, 06-11-2006 14:41:36
Just reread your reply and saw I didn't answer all your inquiries. Yes, the air mixture does affect the idle. Don't know about black smoke. I had it set to idle pretty smooth and haven't messed with it since.
Chris B.
Chris B.
06-11-2006 14:53:32
I have cleaned this carb. Several times, but not for this reason. Looking through the parts book shows several different jets for this carb. I wonder if I need to upgrade. I did put 4" stepped pistons/sleeves in it recently and redid the 8060 head.
Chris B.
Magman
06-11-2006 15:02:33
 Re: M carburetor high speed adjust in reply to Chris B., 06-11-2006 14:53:32
I supose it could be the larger jet needed But a lot of the times people clean and dip a carb but unless you know every orfice in a carb like rusry farmall does you still can have something plugged. Alot of people think that carbs are worn out and need a new rebuilt becuase they rebuild and the jets dont work right when there done. Thats a myth. Ask rusty farmall he will know for sure. JON
champspa
06-11-2006 14:41:25
my 450 carberator was the same way the jet is sized for that engine
