Farmall M manifold Torque specs
MJF
06-11-2006 19:04:50
What do I need to torque my manifold at on my M
Also I'm getting new bolts for the manifold, what should I get stainless,grade 8 or what. Thanks Mike
Tom Windsor
06-11-2006 21:38:49
 Re: Manifold Bolts in reply to MJF, 06-11-2006 19:04:50
You should get studs. Course on one end and fine on the other end. Nuts are fine threaded. You can get an even good torque this way. 5s or 8s both are good.
TW
RustyFarmall
06-12-2006 06:39:44
 Re: Manifold Bolts in reply to Tom Windsor, 06-11-2006 21:38:49
I agree, and the only place I was able to find the correct studs was at my Case-IH dealer. No one else had the correct size.
Nebraska Kirk
06-11-2006 19:16:43
 Re: Farmall M manifold Torque specs in reply to MJF, 06-11-2006 19:04:50
Manifold bolts are torqued to 55ft/lbs.
