Carb. Rebuild
Marty Johns
06-11-2006 19:22:11
A mid 1940"s A carb rebuild, how difficult is it? and since I am asking, I might as well ask about price!
old
06-12-2006 07:58:26
 Re: Carb. Rebuild in reply to Marty Johns, 06-11-2006 19:22:11
Carbs are pretty simple to work on but hard to get all the passages clean as they need to be. You need to open it up, soak it over night or longer in something like Berrymans carb cleaner. Then you need to blow out all pasages with air and or carb cleaner in spray cans. I use both the spray and air when I do one.
Brian Schmidt
06-11-2006 19:27:37
Do it yourself for $19. Pay someone $150. It is a piece of cake. Mainly involves a good cleaning. Everyone has their own way to clean it. Do it however you see fit.
RustyFarmall
06-12-2006 09:30:24
 Re: Carb. Rebuild in reply to Brian Schmidt, 06-11-2006 19:27:37
If the carburetor is from a running tractor, then it probably would be that easy. If it came from a fence row derelict, or from a tractor that has not run in several years, the usual cleaning methods may or may not work. I have rebuilt several that were so full of crud that soaking them for 2 days would not loosen the stuff, and spraying the aerosol stuff into the passages would not dissolve it either. It all depends on the condition of the carb you are working on.
