Order Farmall Cub Parts Online
Cub is finally running
spray004
06-11-2006 20:48:03
Well finally got the Cub running. I had to order a new Zenith carburetor from this website. It was definitely not a direct bolt on. I had to modify the choke so that it would work with the choke lever and I had to add some washers to the mounting bolts. It seems to run decent, but nothing spectacular. If I pull the throttle all the way back it barely runs so i'll have to work on the throttle lever next time I get a chance. Also the tractor is very hard to start without using starting fluid. I'm thinking that maybe the carburetor is out of adjustment and that's what is causing it to have a hard time starting.
In any case 1 down, 3 to go. The 706 just needs batteries, but $70+ each is a hard bite to swallow for a tractor that won't be used all that much. The B just has a weak spark and the Super C has a lot of problems (bad carb and clutch is stuck to the flywheel).
souNdguy
06-12-2006 06:28:54
 Re: Cub is finally running in reply to spray004, 06-11-2006 20:48:03
I have a zenith carb on my 66 cub.. I found it to be more or less a hunk of junk.. but rebuilt it anyway.
Try starting with the lowest throttle setting possible and see if that helps.
My cub runs fine .. has good power and full range of throttle.. but will ONLY start with throttle at minimum setting.. choke or no choke... go figure..
Soundguy
