Order Farmall Cub Parts Online
Farmall Cub data plate
njones
06-12-2006 10:19:16
Farmall Cub - Missing the data plate from our Cub. Trying to determine year and what color the screen grille should be. I have the engine casting number 251341R2 L and the tube casting number 351686-R1. Can anyone provide information from those or know a better way to determine the actual year of production. Thank you.
john *.?-!.* cub owner
06-12-2006 18:58:19
 Re: Farmall Cub data plate in reply to njones, 06-12-2006 10:19:16
try the link below
Bigdog
06-12-2006 14:25:26
If it has a wire mesh grille - it should be red.
Nat 2
06-12-2006 11:50:55
Those numbers you quoted off the castings are part numbers, and narrow down your Cub to having been built between 1947 and 1979. In other words, they're not helpful. Look for codes cast into the castings with the format of "11 22 X." This indicates the date on which the casting was made. At least you'll know what year your the parts for your tractor were forged. The letter indicates the year, and 1953 is indicated by the letter "Y." They started over with A in 1955.
Your engine block may or may not have been changed during the Cub's life. It may have been changed out for a newer block. It may have been changed out for an older block. The serial number MIGHT get you close, or it might lead you on a wild goose chase.
The only sure way to find the serial number is to trace it back to the original owner and hope that the original owner is still alive and still has the original bill of sale. The serial number will be on the original bill of sale.
Harold H
06-12-2006 11:18:06
Look for engine number. It will be close to serial number but not same. Also, look for casting dates on major castings.
Harold H
