Super Av carb
John Finley
06-12-2006 17:13:49
There seems to be excessive amount of gas comming out the air intake, is this normal?
RustyFarmall
06-12-2006 18:05:13
 Re: Super Av carb in reply to John Finley, 06-12-2006 17:13:49
Should not be any gas coming out the intake, you need a new needle valve, a new float, or both.
John Finley
06-12-2006 18:25:29
 Re: Super Av carb in reply to RustyFarmall, 06-12-2006 18:05:13
If I take it apart and clean and inspect, is it possible that will fix it. The tractor has been sitting for some years when I got it.
RustyFarmall
06-13-2006 04:31:28
 Re: Super Av carb in reply to John Finley, 06-12-2006 18:25:29
If the tractor has been sitting for several years, the carb will need a very thorough and complete cleaning. That old gas sitting in the carb can really plug things up,plus, if any moisture got in, you will have some rust problems to deal with as well.
