656 PTO
ANNTKLE
06-13-2006 06:58:14
MY 656 PTO SLIPS UNDER HEAVY LOAD TO THE POINT OF COMPLETELY STOPPING.IT IS PROBABLY IN NEED OF A CLUTCH PAK-BUT IT MAYBE THE HYDRAULIC ENGAGEMENT VALVE -CAN`T FIND A REPAIR MANUAL LOCALLY --STILL LOOKING-QUESTION IS HOW TOUGH IS IT TO DISASSEMBLE AND CHANGE CLUTCH DISKS AND REPLACE UNIT. THANKS TOM
the tractor vet
06-13-2006 07:26:59
 Re: 656 PTO in reply to ANNTKLE, 06-13-2006 06:58:14
It's not that big of a deal to R&R but you have to becareful not to damage the pickup tube when commin out and when going back in . The hard part is having the special fitting to install the test gauge to set lockup pressure and if it has sliped a couple times then the clutches are wiped out . The valve stem is what set pressue and could have backed off and lockup pressure is down . Also you must have the hyd. system up to operating temp when setting the lockup pressure around 150-180 degrees and at this moment off the top of my head i can not remember what a 656 lock up pressure is but more then likely around 235lbs.
