Wiring Diagram for 12 volt conversion
ICRed
06-13-2006 18:02:10
I saw at one time a wiring diagram for a one wire alternator conversion. I am putting back together my Super C and sure could use one, the type I have is a Delco. Does anyone have one the can post? Thanks in advance.
Bob M
06-13-2006 18:14:47
 Re: Wiring Diagram for 12 volt conversion in reply to ICRed, 06-13-2006 18:02:10
Punch below!
F-Dean
06-13-2006 19:51:10
 Re: Wiring Diagram for 12 volt conversion in reply to Bob M, 06-13-2006 18:14:47
Bob, Is the ballast resistor needed if you switch to a 12-voly coil?
Bob M
06-14-2006 04:32:18
 Re: Wiring Diagram for 12 volt conversion in reply to F-Dean, 06-13-2006 19:51:10
Nope!
With a "12 volt" coil you omit the ballast resistor.
