Re-install F-12 Flywheel
Dan Oehmke
06-14-2006 18:17:39
What's the proper way to re-install an F-12 flywheel? Looks like it can mount on the crankshaft studs in two different positions -- but not sure which is right, to ensure the markings on the timing marks are positioned correctly. Other than the markings being in the wrong place, if the flywheel is mounted in the "wrong" position --- does that matter if the mag is timed accordingly?
Thanks,
Dan
Kevin LA-CA
06-14-2006 18:56:19
 Re: Re-install F-12 Flywheel in reply to Dan Oehmke, 06-14-2006 18:17:39
I recall installing the FW on my F-12 over christmas. The bolts only match up one way - they are not uniformly spaced. I must have figured this out by putting it on wrong...
kevin
Dan Oehmke
06-15-2006 18:15:11
 Re: Re-install F-12 Flywheel in reply to Kevin LA-CA, 06-14-2006 18:56:19
Kevin - On my F-12, it seemed like the flywheel could go on both ways, though I couldn't seem to get the last bolt started easily. Was like it was a little misaligned and would strip --- close but not quite. Otherwise the other bolts seemed to go in OK. When I rotated it 180 degrees, all the bolts seemed to go in OK and tighten down the flywheel. So maybe I got it right afterall. Thanks, Dan
