Distillate manifold
Mister H
06-15-2006 03:42:21
I have a 43 H with a dual fuel manifold. The baffle was rusted tight in the gas position. I wanted to free it up but wound up completely removing the baffle. What effect will this have on the way the tractor runs on gas, if any?? I think most of the exhaust will be drawn straight up away from the heat chamber that is now wide open. Opinions please.
muggsw6
06-15-2006 06:02:23
 Re: Distillate manifold in reply to Mister H, 06-15-2006 03:42:21
you're better off without the flapper if just running on gas. The flapper was designed to hold heat in the manifold to better vaporize kerosene. Mark
Tom Windsor
06-15-2006 05:06:24
I am not an engineer...but I had the same problem. The thing down in there was frozen up so I removed the shaft, then the flapper, welded up the holes and put it on there..as far as I can tell...it runs ok for me. You got to be careful breaking this thing loose...cause on another one I made scrap out of the manifold by hitting it too hard! The exhaust has not been a problem.
Mister H
06-15-2006 05:24:43
 Re: Distillate manifold in reply to Tom Windsor, 06-15-2006 05:06:24
By "welded up the holes" do you mean that you closed off the heat jacket or were there some holes in the outside of the manifold that you repaired?
Mr. H
06-15-2006 05:26:05
 Re: Distillate manifold in reply to Mister H, 06-15-2006 05:24:43
Ahhh...I'll bet you meant that you welded up the holes for the shaft??
