Weight Bolts
REtcol
06-15-2006 05:45:34
Does anyone know where I can buy some realistically priced bolts to mount the wheel weights on my Farmall C? I called the local dealer and he wanted $8.56 per bolt. I wanted the square head bolt but I may have to settle for hex.
Dr.EVIL
06-15-2006 09:42:57
 Re: Weight Bolts in reply to REtcol, 06-15-2006 05:45:34
OEM tractor supply advertises IH square headed bolts.... and EASY BOB on RPM Forum has them also.
IndianaMike
06-15-2006 07:54:39
I think the Rural King store has some square-head bolts. Idk if you have one of those close by or not.
El Toro
06-15-2006 07:16:20
This company in Baltimore has square head bolts.
Their phone number is 410-687-8831 or you can fax them at 410-687-0071. Hal
El Toro
06-15-2006 06:55:07
Give this company a call at 1-800-327-6378 for square head bolts. Hal
RustyFarmall
06-15-2006 06:04:54
Your IH dealer is just about the only place where you will find the correct 4 1/2" length bolts. A 4" bolt is too short, and a 5" bolt is not threaded down far enough. Hex head bolts will work just fine. The price you mentioned does seem high, but you only need to buy them once.
muggsw6
06-15-2006 05:53:36
Try Fastenal, I"ve gotten several square headed bolts from them, and they seemed reasonably priced. Mark
