Farmall B Carb ID HELP!!!
Steve Vannatta
06-15-2006 08:56:07
I have a 1948 that I am about half way through with the rebuild. I have removed the original carb from it and have it soaking at this time. I know it is a Zenith, but do not know what model #. Do I worry about a rebuild kit (has a lot of build-up) or do I just by new. Have done some looking...manual says it could be a 10514 or one other model (9752?). Could really use some help with this one. THANKS! You can email me direct at vanattafamily@iowatelecom.net if you like.
Charles McNelly III
06-16-2006 18:58:36
 Re: Farmall B Carb ID HELP!!! in reply to Steve Vannatta, 06-15-2006 08:56:07
1947 was the last year of the B. You can get a carb. kit from NAPA. Good Luck, Charles
Dave BN
06-16-2006 06:03:26
I don't remember the carb number but the Case/IH dealer in your area should know. Take the carb along with you for verification. You can go to NAPA also. Dave
MM_TX
06-15-2006 15:23:29
There should be a round brass tag rivited through the center on the top of the carb with the number.
this link might help
http://www.thecarburetorshop.com/Tracfarmall.htm
