starter ring gear removal
CG Campbell
06-15-2006 18:25:22
Years ago, as a kid, i watched my dad remove the ring gears on several Ford and Ferguson tractors after splitting them. I can't remember how he removed the ring from the flywheel. Would I be correct in saying that he heated it with a torch? Is there a better and safer way today? i am talking mid to late 50s when this was happening.
Geoff NY
06-16-2006 14:35:33
 Re: starter ring gear removal in reply to CG Campbell, 06-15-2006 18:25:22
We heat with a torch evenly around. It drops off then put it right back on flipped over (no new gear). The starter only meshes on one side, so the other side is most often like new.
CG Campbell
06-16-2006 14:59:15
 Re: starter ring gear removal in reply to Geoff NY, 06-16-2006 14:35:33
Thanks Geoff, that will save me a few bucks.
Geoff NY
06-16-2006 14:35:37
CG Campbell
06-16-2006 06:43:30
This is great information. I really appreciate all who replied. It will be a great help. I did remember the way you install one, so maybe my mind is only half gone. By the way, I am working on a 1948 H which my Mom's 1st cousin bought new. Runs great, just needs some of those worn things taken care of. THANKS AGAIN
f20inmi
06-16-2006 05:39:06
I used my die grinder and a cut off wheel to cut through the old ring gear. It will pop when you get a portion of the way through so be ready.
Heated the new one on the gas bbq grill and slid it on.
Easy
souNdguy
06-15-2006 20:40:44
Drill almost all the way thru it.. then split with a chissle... heat new one and drop on.. allow to air cool.. don't quench.
Soundguy
K.B.-826
06-15-2006 20:27:25
A few good solid blows with a hammer and large punch will take it right off. To install the new ring gear, heat it to 350 degrees evenly. I have done this with a torch, but an hour in a 350 degree oven would heat it perfectly even and it will slide right on.
john paul przytarski
06-15-2006 19:10:31
yes you have to heat it with a torch to get them off. also heat the new one to put it back on
randy hall
06-15-2006 19:19:45
 Re: starter ring gear removal in reply to john paul przytarski, 06-15-2006 19:10:31
i just changed the ring gear on my 1466 and didn't heat it. i have never heated a ring gear to remove it.
randy hall
06-15-2006 18:50:41
you do not need to heat it, you need to just drive it off with a large punch and a good sized hammer.
MAGMAN
06-15-2006 18:38:28
I would say that thats the best way but I have heard others talk about baking them in the oven also. You will need to heat the new one to install also. MagMan
RustyFarmall
06-15-2006 18:36:19
You can remove them by splitting the ring with a chisel, but you need to heat the new ring to expand it so it will fit over the flywheel. I have heard of placing the new ring in the oven for awhile, never tried it that way.
Bob
06-15-2006 22:13:31
 Re: starter ring gear removal in reply to RustyFarmall, 06-15-2006 18:36:19
The wife's oven works GREAT. Just make sure she has the credit cards and send her to WaldoWorld for a while.
Or, better still do what I did and scarf up a kitchen stove and put it in a corner of the shop, just for this use.
