Order Farmall Cub Parts Online
Cub 1948
Lucien Cyr
06-16-2006 15:42:22
I have a Cub 1948 and it run for about 20 to 30 minutes and while stop and want start till it cool down . Could it be the coil or the condenser or something else? Thank's for the help.
Lucien Cyr
06-17-2006 04:11:33
 Re: Cub 1948 in reply to Lucien Cyr , 06-16-2006 15:42:22
Thank's Old, next time he does that I will check the fire to the spark.Yes it is a magneto.
old
06-16-2006 15:51:43
Might be your ignition switch, or coil. Is it a mag or a distubtor type system. If its a mag then its probably the coil but you need to do a little trouble shooting first. When it dies check to see if you have spark and what the spark looks like. It should be a nice blue spark. If you have spark you could also have a carb problem and its not getting fuel as it should be
