F-30 rear wheel qestion?
Mopower
06-17-2006 10:24:12
What size rubber was available on the F-30/20? Was there different size steel wheels? Would like to use some wheels for 34 or 38 inch rubber on one. Cut-offs? What"s my best option for that tire size using spoke wheels?
brad NC
06-17-2006 18:25:39
 Re: F-30 rear wheel qestion? in reply to Mopower, 06-17-2006 10:24:12
steel 10.00x36 11.25x36 11.25x28 12.75x28 rubber F&H 34 F&H 38 or40 for high crop most have F&H 34
Dean
06-17-2006 18:25:02
Mo:
My uncle farmed with an F-30 until he died in 1986. It had the original round spoke wheels front and rear. The rear tires were 12x28s (13.6x28). I do not know if optional rubber tire sizes were available.
Dean
SproutW
06-17-2006 13:07:18
Just so you know the rims for an F-20 and F-30 will not interchange. I"m familiar with the F-20"s and they had several different size tires available. 28 and 36 inch rims are the most common. Not to many came from the factory on rubber tires. Most farmers later on simply had the old steel cut down and a rim welded on the spokes. Much cheaper that way.
