Order Farmall Cub Parts Online
When did Cub go from 6 to 12V?
'nother cub own
06-17-2006 19:27:58
For the "regular" size Cub, not the Lo-boy. I think mine is a 1959 with 12V. Thanks in advance!
wallysparks
06-18-2006 19:18:54
 Re: When did Cub go from 6 to 12V? in reply to 'nother cub owner, 06-17-2006 19:27:58
mine is a 1956 regular cub with a 12 volt positive ground and generator based charging system.
'nother Cub owner
06-18-2006 05:54:39
 Thanks! in reply to 'nother cub owner, 06-17-2006 19:27:58
I saw that site before posting here but didn't find that info. The first two numbers of my serial # are illegible so I was 'guessing" by the front grill type. The PO had a 12V battery on it...dohhh! Something else to 'fix'. Thanks again!
Redned
06-17-2006 19:57:55
All Cub tractors manufactured prior to serial number 224401, and Lo-Boys prior to serial number 18701 utilize a 6-volt POSITIVE ground electrical system, this was changed in mid 1964 to a more modern 12 volt negative ground system. The generator based charging system was replaced with an alternator at serial number 248125
This was taken off the ATIS site on Farmall cubs please check it out for useful cub information
Redned
06-17-2006 20:01:14
 Re: When did Cub go from 6 to 12V? in reply to Redned, 06-17-2006 19:57:55
Oh! yea the site sorry.
http://www.antique-tractor.com/CubFAQ/cub_faq.html
