Filter for 300U Wagner Loader Hyd Pump
Kerwin
06-18-2006 06:12:35
I need to install a filter in my 300U's loader hydraulic system. It's a Wagner loader with a pump run off of a front PTO shaft. Originally there was a strainer on the suction side of the pump, but that was lost by a previous owner so it's running unfiltered at the moment.
I would like to add a 25 micron spin-on filter in place of the strainer. With it on the suction side (and not return), will this put too much strain on the pump? It will be using 3/4-inch. NPT, which is what the original strainer was plumbed with, from what I can tell. I figured the 25 micron would be a little less restrictive than a 10 micron. Any thoughts? Thanks.
PAULIH300
06-18-2006 08:50:53
 Re: Filter for 300U Wagner Loader Hyd Pump in reply to Kerwin, 06-18-2006 06:12:35
I dont believe you could put it in any line but the return.The suction side would probably suck the paper element right out of the filter.WIX/NAPA has a spin on base that can be plumbed in with 3/4 or 1" pipe thread.
