Farmall H Pulley Bearing
Joe Dowling
06-18-2006 08:44:40
My 1952 "H" has the metal side belt pulley. (Original)
It (the pulley) hasn"t been used in 30 or 40 years and when I turn it by hand it sounds as if there is a bad bearing in it. Where can I get the parts manual that will tell me what the bearings are?
gene bender
06-18-2006 11:54:02
 Re: Farmall H Pulley Bearing in reply to Joe Dowling, 06-18-2006 08:44:40
If you are not going to use the belt pulley for anything dont worry about it. If you are going to power something with it then i would replace the bearings.
Wayne Swenson
06-18-2006 11:30:51
They are common bearings; #203, 204, 205, 207 (forgot the exact number). Take it apart & go to NAPA or even find a used one at an electric motor repair shop. The ones they replace on a rebuild work well when lubed with gear oil. Remove the side shields, check them over, & use the best ones. I have gotten them for no cost or scrap iron price.
With a pulley that is used 1-2 times a year at a show the investment is just right.
Farmer Bob
06-18-2006 08:46:47
Several sources for all kinds of manuals are available. The best manuals for the price in my opinion are available at Binderbooks dot com.
