Electrical hook up for switch, fuse and ignition o
andy r
06-18-2006 19:50:52
Thanks everyone for sending the parts blowup of the electrical system. I can't see how things hookup. Someone really messed things up in past years. Help me by answering these questions... International 544 gas utility.
1) I assume the starter button is only powered when the ignition switch is turned on. Is the current to the ignition switch and subsequently the starter button ran through the fuse holder or does it just get current from the hot side of the fuse?
2) When the switch is turned on it powers the coil and the push button starter switch. Does anything else hook to the ignition switch?
3) Did this tractor have 12 volts sent to the coil when the starter button was pushed and when released ignition switch current sent through a resister to the coil or was the coil always receiving 12 volts?
It seems like the 544 is alot like a 560 or 706 when considering the electrical system. Thanks for helping. andy
Allan In NE
06-19-2006 04:32:55
 Re: Electrical hook up for switch, fuse and igniti in reply to andy r, 06-18-2006 19:50:52
Andy,
Those old IHs are pretty much wired all the same.
The fuse is for the lights only and the dash lights are fed via the right buss junction connector.
The ignition switch sends current to the center buss junction. From there the ignition, starter button and all the gauges are fed.
The left buss junction is hot all the time. Cigarette lighter hooks here.
The 12 volts to the ignition coil when cranking is furnished by the starter solenoid.
Allan
