1066 PTO Pressure Check UPDATE
Michael Sheik
06-19-2006 04:45:46
Thanks Tractor Vet for the info last week. Called my Case IH mechanic buddy and he gave me his gauge and fitting setup to check the PTO clutch pressure. When I plumbed in and checked, it was running at 390 psi @ pto rpm. at idle it backed off 30 pounds and partial engage pressure was 42. I reset the high end to 285 and good to go. Glad I haven't use pto since replacing rubber boot on stem. Also glad I checked before I blew something out.
My buddy also is going to make a house call to set my clutch and TA so it will shift easy.
the tractor vet
06-19-2006 08:13:39
 Re: 1066 PTO Pressure Check UPDATE in reply to Michael Sheik, 06-19-2006 04:45:46
You did set that pressure when the hyd. oil was at operating temp i hope . as it will drop off when warm . Ya want the pressure to hold that pressure and if ya set it cold then it may drop on down to low .
Michael Sheik
06-19-2006 09:39:53
 Re: 1066 PTO Pressure Check UPDATE in reply to the tractor vet, 06-19-2006 08:13:39
Yes Sir I did.
Thanks
