H Short?
Ryry
06-20-2006 07:15:07
All right i poasted about a week ago about a H that wont start. Well i bought a new 6 volt coil for it and with the week battery it had it would turn it over barley then stop so then i new i had fixed it. Just went out and bought a new 6 volt battey put it on put some starting fluid in it and she turend over but she wont start and at first the voltage regulator was smoking a little stram of white smoke. Then The battery termanal comming from the swich (NEGTIVE) it had a little stream of with smoke went to take the negeave cable off and the cable was hot burriup but did not melt the wire. Could some one tell me whats going on what do i do. Thanks Ryan Also when you put the ternimal on from the swich she sparks a little.
old
06-20-2006 07:29:01
 Re: H Short? in reply to Ryry, 06-20-2006 07:15:07
My guess is that you hooked it up with the wrong ground and fried the voltage regulator and that fried the switch and battery cable. Some regulators don't care which way there hooked up others do and will burn thing out if hooked up wrong. An H should be hooked up + ground unless some one has switched it to - ground and most of the time that only happens when an alternator is put on. But who know what has been done to a tractor that is 50 plus years old
