H and Little Genius
Trent M
06-20-2006 21:00:26
Have a chance to get a little genius 2-14 for the H. It looks real nice in the pictures I've seen. My question has to do with the steel wheels that are on it. I think that's great, but I want to use the plow, take the steel wheels off and put on tires. Would this be easy to do? Could you maintain authenticity? I'm not very mechanical, so any advice is appreciated.
BillyinStoughton
06-21-2006 07:29:11
 Re: H and Little Genius in reply to Trent M, 06-20-2006 21:00:26
Hugh is right...it is just a matter of hubs and rims to mount the rubber. I saw a #8 on steel go at auction over the weekend that had the pieces to mount pneumatic tires...and by looking at the parts, it is just the hubs and rims you will need.
Good luck with it!
Billy
RustyFarmall
06-21-2006 04:47:26
Where do you live? If you are within driving distance of southwest Iowa we might work out a trade. I have a parts plow with the rubber tires.
Hugh MacKay
06-21-2006 01:36:55
Trent: Just to add to what gene has said, and if the plow is a No. 8, production of those plows started in 1928 and continued until 1960. Rubber tires became an option in 1940. I would expect it was just a matter of changing hubs and wheels. As an option on a new plow in 1940, rubber tires only added $12.50 to the base price.
Close to 67,000 copies of the No. 8 Little Genius were sold in that 32 years. I cant find anything on how many went out with rubber tires, I doubt if anyone knows. It was quite common to see these on rubber after the war. Your best bet is find a parts plow on rubber.
gene bender
06-21-2006 01:03:32
There were models of the same type you seen that have rubber as rubber was an option.Now where to find one is the question.
