What size U Bolts to connect H fenders??
CharleyFarmall
06-21-2006 18:58:12
I aquired a set of nice fenders for my H which i want to put on tomorrow when I go out to our farm. I need to stop and get bolts but don't know how long...
Thanks.
GordoSD
06-22-2006 05:02:54
 Re: What size U Bolts to connect H fenders?? in reply to CharleyFarmall, 06-21-2006 18:58:12
1/2 NCx 1 1/2 inch. One flat washer, one lock washer.
Gordo
Don L C
06-21-2006 20:22:50
Bolting the finders directly to the housing puts the finders close to the seat.....making it hard to get on and off....they make extender plates or you can make your oun, using 7/16" flat stock as wide as the finder mount and long enough to put the finder out even with the housing.....also cut 1" pieces of (i think) pipe to put under the plate on (on each bolt) the inside to hold the plate up off the housing....bolt finders directly to outer end of plate..... thats what I am going to do on my M ..... .hope this helps Don
Michael Soldan
06-22-2006 04:53:19
 Re: What size U Bolts to connect H fenders?? in reply to Don L C, 06-21-2006 20:22:50
Hi Don, I agree that many folks make an adapter to set the fenders out a few inches further. However I have never found it difficult getting on and off with the fenders in their standard position. I have two H's and an M all with fenders in the standard position. I guess its personal preference. I think fenders are better mounted by raising them an inch or so using longer bolts and spacers, again my personal preference...Mike in Exeter Ontario
brainerd dave
06-21-2006 19:04:08
H fenders don"t attach with U-bolts. They bolt directly onto the axel housings using standard bolts. Don"t know the size offhand.
CharleyFarmall
06-21-2006 19:06:00
 Re: What size U Bolts to connect H fenders?? in reply to brainerd dave, 06-21-2006 19:04:08
Thanks! That makes it easy. I have regular bolts to play with.
