Dan in ORE
James Williams
06-22-2006 11:59:30
Dan,I welded my F12 and the cast welded perfect,The welder that did it said it was virgin cast,Did you receive the pictures I sent you
Jimmy
Dan in Ore
06-23-2006 06:20:59
 Re: Dan in ORE in reply to James Williams, 06-22-2006 11:59:30
A little food for thought about welding cast iron.
This company has what I need, but they are pretty expensive. I am trying to do this on a budget as are most of us.
We'll see what happens with the pipe plugs.
Dan
Dan in Ore
06-22-2006 15:15:40
This is inside on the water jacket. I can't find any of the tapered pins, so I went in and put in some 1/8" pipe plugs and overlappped them. I put some Loc-Tite on the threads. Then I will hit it with a wire wheel and put JB weld over the whole mess. Hopefully that will do it. Am trying to get by without pullin the engine.
Will post some pics of what I'm doin.
Dan
