Pistons in H
HicksDale
06-22-2006 17:23:29
I got a Tisco engine rebuild kit for an H. The pistons that came have a stepped top. The top goes up almost 3/8 inch above the top of the head. Will this be OK? Thanks. DH
El Toro
06-23-2006 04:01:44
 Re: Pistons in H in reply to HicksDale, 06-22-2006 17:23:29
If that cylinder head has been milled a lot, that may be a problem. I would hand crank the engine
after installing the head and rocker arms to make sure the pistons and valves clear. Hal
Janicholson
06-22-2006 20:37:58
Unless your cam came from the wildpart of thepulling circuit, it will be fine.
JimN
