wont crank over
ToddH
06-23-2006 07:48:23
Until I figure out why my Super C wont crank over, is it ok to just use jumper cables directly from battery to starter motor. I just need to do a quick job and then I will have time to diagnose the problem. Thanks for any comments, Todd
Guyzoo
06-24-2006 10:16:12
 Re: wont crank over in reply to ToddH, 06-23-2006 07:48:23
Be sure there is no gas seepage around because you will set the tractor on fire--like I did two years ago with a lawn tractor LOL
Otherwise there is no problems
arod
06-23-2006 17:13:31
I have jumped my "M" like that before, sparks do fly for sure, but it worked!
ToddH
06-23-2006 08:19:24
 Thank you very much! in reply to ToddH, 06-23-2006 07:48:23
kfox
06-23-2006 13:29:39
 Re: Thank you very much! in reply to ToddH, 06-23-2006 08:19:24
Just don't kill the engine 2 miles from home:-(
ken
Bob M
06-23-2006 08:03:41
I've had to do that on several occasions and it works fine.
Just be mindful and take into account ground polarities before making the jumper connections!! Your Super C is probably positive ground, but essentially all modern vehicles, tractors, etc are negatively grounded...
RustyFarmall
06-23-2006 07:51:58
If that's what it takes go for it. It would be a bit of a hassle to do it that way everytime, but you sure won't hurt anything.
