b block swap
scotc
06-23-2006 15:05:16
I"ve been thinking about what all I am going to do with the B when I get around to fixing it up and am thinking I would like hydraulics. I"ve heard that some of them came with an A block and the live pump could be mounted to the motor and a system set up. If I switch to another block I was thinking I may as well step up in displacement too. Would a super A or C, 100 or 200, 130 or 230 motor fit in a b and allow me to put the hydraulic pump on it? Or would the steering shaft get in the way? The cost on top of the powder coating and pearl coat paint may kill this idea though.
gene bender
06-23-2006 19:49:39
 Re: b block swap in reply to scotc, 06-23-2006 15:05:16
If you decide to go to a newer block all you need is a longer shaft extension on the steering sector to allow clearence for the pump. I have made a couple not hard to do then you can use a pump from an SA,SC or so.
Dave H (MI)
06-23-2006 19:32:57
Just saw a nice BN that had a pump mounted on the back end with a pully on the PTO shaft. A little joystick on the pump gave it two way action from the looks of it. Looked like a good alternative and it fit right on there like it was stock.
Dave_Id
06-23-2006 16:30:41
You can get yourself a pto pump for a lot less than a different block
